help has my evinrude 9.9 hp got 12v output???
willowkevin
the numbers are - b11230 and the smaller number is 109b63b as on the engine plug there are 3 wires coming out of the casing but i dont know what there for ! can anyone please explain to me ??? the wires are yellow one has a blue spiral stripe on it
OBJ
Re: help has my evinrude 9.9 hp got 12v output???
Kevin....the numbers you posted don't ring no bell (maybe my bell's broke, don't know) but could you look on the transom bracket for a metal tag with the model number and serial number on it and post if possible?<br /><br />If your 9.9 has charging, on the starboard side of the engine, that's the right side when looking from the back of the engine, there will be a triangular mounting base with a small tin can on top. There will probably be three wires coming from it. Two yellow (with blue and grey stripes) and a red. The two yellow wires will connect at a terminal strip with wires of the same color coming from under the flywheel.
willowkevin
the number on the engine is similar just a 0 at the beginning ? there are three wires coming out but none is red ? its got me puzzled but i dont want to tamper with it ! cant get any advice from local boat yards
