This one's likely a no-brainer, but I'm still collecting my boating brains.<br /><br />1975 Evinrude 20hp. <br />Mod# 205B62B<br />Ser# C96083<br />I tried out the generator and found that it's working. Hooked up a couple single filament auto bulbs as a test. <br /><br />The manual specs the output as AC power at "45 watt at 12 volts"<br /><br />So I guess I can run my white light and my bow light, and that's about it. I was thinking of putting in a small battery (along the lines of an ATV or lawn tractor battery) to power the lights when I'm fishing late in the evening. But, having 12v AC, I can't charge the battery off the generator. Or can I ?<br /><br />If I convert AC to DC with a rectifier I'll end up with 6 volts, won't I?<br /><br />And can I use regular automotive bulbs? Will I be replacing them every time I turn around because of powering them with fluctuating AC voltages?<br /><br />Or, should I just hook the darn things up with an inline fuse and the pull switch and shut the heck up?
