83 evinrude 115hp carb cleaning help
fsds123
I want to clean the carbs on my 115hp 1983 evinrude. I noticed they sell carb gasket kits for around $10-15. Anything else while the carbs are off? Do they sell kits with more parts that might need replacing since I am taking the carbs off anyways?<br /><br />Thanks
D
DJ
Guest
Re: 83 evinrude 115hp carb cleaning help
fsds,<br /><br />While you are at it.<br /><br />1. Get new cab base gaskets (carb to intake).<br /><br />2. Get new carb to air box gaskets.<br /><br />3. Rebuild the fuel pump.<br /><br />3. Replace the fuel hoses.<br /><br />By the way, if you haven't put in a new water pump in a while, now is the time to do it. The shift linkage is super easy to get to when the carbs are off.
