Johnson 1983 115HP V-4
rscott
My motor wont perform to its fullest potential.In wot boat only goes 10mph.Compression at 125lbs/1,2,3 & 4.Good blue spark on all 4.Fuel mixture 50:1.Carburater and fuel pump cleaned.New gas tank,lines.When adjusting timing noticed no difference.........Anybody have any suggestions?
USS Neversail
Re: Johnson 1983 115HP V-4
Checked the reeds and fuel pump? Are the rpm's high with no speed or is she choking out?
rscott
Thanks USS, my motor runs great at idle,revs good but lacks topend.
Dhadley
Describe further what you mean by "adjusting timing". Whats the top rpm's?
rscott
With engine running on water.its impossible to adjust.turned off engine loosened nut and tried to adjust timing with light difference not found.I pulled flywheel,because the timer base didnt seem to be attached...
Dhadley
So youre saying the timer base doesnt move as you advance the throttle? What was the timing set at?
rscott
Its suppose to be at 28degrees.....<br />I feel my timing may not be advancing.It takes of fine but only travels about 10mph.It idles good,puffs every once and a while.but it revs strong....
rscott
Could this problem be my stator.
rscott
USS the rpms are high wirh no speed........
D
DJ
Guest
rscott,<br /><br />Is your prop hub spun?
rscott
Djohns in gear out of water i cant spin my prop.....is there another way to tell if its spun?
D
DJ
Guest
rscott,<br /><br />I am thinking that your engine winds up (rpm's) but just doesn't move the boat-right?<br /><br />If so, try this. Put a mark on the prop hub and a corresponding mark on the prop outer housing. Run the boat and see if the marks are still lined up.
rscott
Yes plenty of rpms,my propeller turns and makes boat move through the water but just not very fast.thanks djohn im a new otboard owner but love to fish/need to go down the lake...
rscott
djohn are my reed valves behind my carbs?
Dhadley
Does your timer base move when the throttle is advanced?<br /><br />When you had the timing light hooked up, what was the timing set at?<br /><br />What top rpms are you getting?
rscott
Dhadley the timer base is not moving enough because when i pulled the flywheel with timing adjusted all the way out it wasnt pointing toward the frt of the boat......it suposed to be at 28",but it never changed from being way out....At full throttle not in gear im getting around 4500 rpm.
