Warm -up Lever
Jkurtz29
My '89 Johnson 175 HP has a warm up lever that I have never used (only had the boat for 2 months). I can usually get the thing started with 2 or 3 cranks and the thing just idles great (cold start). I was wondering if I should be using the warmup lever instead? I'm I doing harm by not using the lever? What advantages are there to using it. Thanks for your help.<br /><br />Jason
D
DJ
Guest
Re: Warm -up Lever
jkurtz,<br /><br />If it starts/runs without it, great!<br /><br />If you do use it, keep the rpms down in nuetral. Usually, you should never have to lift it more than halfway.
CharlesW
Re: Warm -up Lever
When I got my first Evinrude, (used), with no manual, I didn't use the warmup lever for quite some time. I didn't even know what it was for until my mechanic told me. Not only that, I didn't know anything about the electric choke. It anazes me that I ever got the thing started. It certainly starts easier using the devices the factory provided. :D <br />Charles
Hooty
Re: Warm -up Lever
My V6 starts hot or cold w/o the warm-up lever. <br /><br />c/6<br /><br />Hooty
PDS
Re: Warm -up Lever
Bottom line is, if it works and not broken, leave it like it is and enjoy it. PDS
