att:- dhadley - 120/140 block venting
93bronco
Ensign
(i had saved the post you wrote to someone else -but with the new filing system i cant access that post)<br />----------------------------<br />im getting ready to drill the hole for the elbow, what i remember is to drill one of the flat sides of water jacket on starboard side 1/2in back. <br /> ?/ \ <-- .<br />-<br />now what side is better, the outside i have the <br /><-- pointing to, or the ?. <br />or does it even matter, i know i just need to make sure the hose will get to overboard T & not get in the way of powerpac.<br />-<br />the other is that- its not all that thick in that area, concern is that hole mite affect head gasket at some point if it over heats.<br />-<br />only you know for sure. thanx
Dhadley
Re: att:- dhadley - 120/140 block venting
Either side is OK. I've seen it on each side but it really makes no difference. <br /><br />The head gasket will never know the fitting is there.<br /><br />Good luck!
93bronco
Ensign
thanx <br />didnt know if one side was easier than the other - in the hose routing dept/hood being taken on & off.<br />-<br />too bad there isnt one directly behind the rectifier.<br />i was looking at the center water jacket on the other 2 blocks i have.<br />with the flywheel off it looks to be easy.
93bronco
Ensign
havent drilled hole yet, but my engine hoist came over ( 2 6ft 9in 300lb redneck swamp boys) to lift motor onto housing.<br />-<br />used 2 bolts to hold gasket in place along with stud. seems just a little (1/16 to 1/32) to one side, but all bolts went in no problem- so i hope it will be ok.<br />-<br />gotta finish venting upgrade, along with t-stat upgrade.<br />then wire it up.
93bronco
Ensign
dhadley- have been trying to find those posts,<br />but i remember something about puting a fitting rite behind rectifier.<br />would this be a better place to put it, being ive been stalled by all the rain.<br />thanx
Dhadley
We always went for the highest spot on the block which is right above #1 cylinder. The old CCC race motors were vented next to that area.
