Jhonson Venom 225
Basscat1
I have a 1993 Jhonson Venom 225 hp carderated motor. Ran it for about 15 minutes and when you got it up running it wouldnt take the last 1/4 of throttle. When you mashed it on down you could feel it loading up or flooding and loosing bout 100 rpm. I ran it for 15 minutes when i blew apart or broke a spark plug into on the ceramic part. Checked compression and all was 95 # except for the top right cylinder at 105# which is the one that broke the plug. What could be my problem here and what should i check first?<br />Thanks
Hooty
Re: Jhonson Venom 225
I've seen the ceramic blow out of sparkplugs before. Not often, but it's not unheard of. You should be able to replace the plug and everything be ok. <br /><br />c/6<br /><br />Hooty
