Re: 1975 70hp Evinrude has no vacume in cylinder
having a borescope laying round is slim to none, might want to try an look into this a little futher, id pull the carbs and check the reeds, your compression, good as it is, leads me to think we should look at the easier steps first, 2 bolts and the carb is off, look carefully with a flashlight at the reeds, make sure they are all there and against the stops, you can poke them with a finger or lightly with a screw stick, id would also consider pulling the head, unfortunately there is no bypass covers on that engine, if you have a spun sleve the compression will still be there, but nothing else, how is the engine reacting to full power, ????
