1994 25 hp Johnson lower unit
jwest
I can not get the shifter linkage loose so I can remove the lower unit.<br /><br />Model J25TEEND<br /><br />Thanks,<br />Jerry<br /><br />jwest@bsc.edu
OBJ
Re: 1994 25 hp Johnson lower unit
Hi ya' Jwest....<br /><br />Could you post a model number for your engine please. There is two different gear cases for that year....one is a split gear case and the other is a solid housing. Shift linkages are different on both.
jwest
The model is J25TEEND<br /><br />s/n G 03034225<br /><br />Thanks,<br /><br />Jerry
