Just bought used 90 115hp Johnson and had Johnson<br />service facility replace fuel pump, plugs, all fuel related hoses, cleaned gas tank out, new flywheel, new internal wiring harness, new water pump, new carb kits. Engine has same prob it had when I took it to the shop. Have to manually advance throttle to keep it running at idle.<br />Backfired and caught on fire first time I tried to start after getting out of shop. In addition,<br />it will run just fine for a while at 5500 and the next time I start it up it will only run about 2300 at full throttle..Stop it and restart and it may run at 5500 or it may run again only at 2300.<br />Would appriciate any and all suggestions..Thanks<br />BTW This is my first posting to the list..New member..Frank<br />P.S. VRO disconnected and am mixing oil and gas 50:1
