gelcoat problem
pursuit2460
I am having a problem with gelcoat the i am appling on some sections of my boat. After the gelcoat dries and i go to sand it, it feels like there is a thin film of wax or resin on the top. It always clogs up the the sand paper until the film is gone. I add the same amount of wax additive as I do with the MEKP. Do I need to add more wax additive or not add any at all. thanks
Twidget
Re: gelcoat problem
You might want to ask in 'Boat restoration and building". Probably stand a better chance getting an answer.
Terry H
Re: gelcoat problem
If you are adding wax that's what is clogging your paper, clean with acetone first. Best bet with gelcoat is to seal it from the air for a good cure. It's not intended as a topical finish, and will be a pain to use that way. Chief.
