txbasshntr
Thread starter- Joined
- Sep 13, 2003
- 34
I have got a real head scratcher. I have a 1971 evinrude 115hp that will not crank. I started with no spark and replaced power pack. Now I have spark on all four cylinders but not at the same time. There is a warm up lever on control box and when lifted 3/4 up I have fire on only #1 and #3 cylinders and no fire on the other 2.<br />But when you move lever down towards run position i get weak fire on all four at about 1/2 way up on lever and with lever down in run position I get fire on #2 and #4 but none on the other side. I have pulled flywheel to check gap at timer base and inspected stator and timer ok.<br />Resistance checks ok on all componets and i replaced two cracked coils but it wont crank. It will hit and try to run for a second but thats it. Any ideas?
