HELP! Does anybody know how to un-stick carb float needle valves without removing the carbs and doing a rebuild? Have lightly tapped float bowls with a small hammer with neg results. My Evinrude 100 will start up and run perfectly, then after shutting down, will not restart. Spark is OK (motor will burn ether), also have plenty of fuel to the carbs (checked fuel pump to carbs, float bowls have plenty of gas in them). Motor was sitting for 2 years, but now am running clean hi-test at 50:1. Am convinced it's stuck float valves, but need to free them up. Motor has the Model G carbs.
