plastic long knob,what for?
Wolf31
could anybody tell me how to regulate if is there any way to adjust the long plastic knob next to the flywheel
Hooty
Re: plastic long knob,what for?
I wonder, are you talking about the timing advance screw? But that ain't plastic.<br /><br />c/6<br />Hooty
Wolf31
it is a long knob (plastic) with a lock nut (plastic) and it is located under the flywheel to the side and it goes conected to a bracket who moves open the carburators .
seahorse5
The all plastic knob assembly sets the synchronization between the amount of spark advance and the throttle opening. There is a procedure in the service manual about it. If I remember correctly, with the motor in gear on the water and the rpm exactly at 900, you set the knob to just start the timer base advance movement.<br /><br />On later motors, there was a stainless steel screw and locknut sticking out that advanced or retarded the timer base to set the idle rpm.
Wolf31
sound very eloquent lol.<br />i did not get a thing of what you said.<br />could you be more specific,please.<br />like how to regulated as close as step by step<br />as you can.<br />thanks
Solittle
Wolf - In order to get any meaningful help here you at least have to tell us what motor you have. What you are referring to, I think, is the timing adjustment. It is usually done in conjunction with setting and adjusting the carbs - called sync & link. Both are best done by using the shop manual for your motor.
Hooty
SoLittle's got tha hot ticket. U-needa-manual.<br /><br />c/6<br />Hooty
Wolf31
oh ithought you knew the engine because they ask you that in the registration ,sorry<br />225hp,johnson 1987 i think.<br />and i do have the outboard manual but they talked about tachometer and sound kind of confusing and i thought there was a trick esier way to adjust it<br />like two turns here and 1/2 turn back, that type of thing.<br />let me know<br />please
