1975 9.9 JOHNSON RECOIL
FISHERKING
Hello All<br /><br />I was out on the lake tonight and it seems the recoil on my 9.9 has re-coiled for the last time, If someone could shed a little light on the basics of changing it out, I would apreciate it. <br /><br />Thanks in advance ....<br /><br />FISHERKING :)
JB
Re: 1975 9.9 JOHNSON RECOIL
Howdy, Fisherking.<br /><br />Servicing a recoil starter is about as dangerous as anything you can do with the engine not running. That spring is faster than a cobra and sharp as a razor if it is broken.<br /><br />It is not difficult if you have the Manual and follow it closely.<br /><br /> http://www.outboardrepairs.com/manuals/ <br /><br />Good luck. :) <br /><br />Heavy gloves and safety goggles are a good idea.
FISHERKING
Thanks for the advice on the saftey issues,I will be sure to keep that in mind ,I was wondering if someone could just give me the basic run down on how it is dome ...I am looking to get the manual but I need to replace the spring tomorow ....<br /><br />Thanks
I know it can be a dangerous process, and possibly a long one. I assume you have the spring at hand. <br /><br />Here is some instructions, not sure if it will help you much...<br /><br />Reinstalling the Manual Starter Spool: New rope is 5/32" dia & 72" long. The spool has to be replaced in the proper location. The underside of this spool housing has a 90 degree metal lug protrusion that hangs down & goes into a round hole in the base that the unit bolts onto. It is hard to see where this protrusion goes unless you place a felt pencil mark on the housing in line with this metal protrusion. There is a washer between the mounting housing & the starter spool. You need to have the anchor bolt backed almost all the way out of the housing (but not all the way, otherwise the coiled spring may pop out of its housing) when you place the unit in position. If when you get the spool unit in place & the metal protrusion in the hole, but have problems aligning the bolt into the hole, hold the unit together as best you can & you can remove the bolt. Now you can look down thru the bolt hole & align the hole in the housing to the threaded hole in the base. The flat washer needs to be installed under the anchor bolt's head, otherwise the starter gear will not stop on it's upward motion & bind in the flywheel gear teeth.
rodbolt
Hello<br /> this is one of the times I would suggest an expert. there is 14 feet of spring in that tiny housing. if it gets away from you it can seriously hurt you. if you are careful you can take it off and take it to a dealer and have it done and secure it together with a 3/8 bolt and nut. then reinstall it later.<br /> if you do it yourself then do it in a place with a clean floor and no one else with safty glasses.and read the manual once or twice. its not hard just touchy. if you think it is going to go SPRONG throw it and close your eyes :) :) :) <br /> good luck and keep us posted
FISHERKING
Thanks for the help guys , a friend and I got it all together and managed to avoid getting injured....love it when a plan comes together... the advice was much appreciated ...<br /><br />CHEERS.... :D
