I have problems with engine running very rich at idle. Compression is 95 psi on all cyls. VRO unit has been disconnected and plugged properly. <br />I have meticulously cleaned the carbs twice (no problems found). I have performed a "link and sync" (all was OK, no adjustments were necessary). Plugs all show to be equally wet (not dry) with moisture (fuel, not water).<br /><br />I do have a JohnnyRude manual, which I have tried most everything suggested. Unfortunately they do not discuss the "not using the VRO and using pre-mix" scenario.<br /><br />When cold and at idle, engine runs slightly rough (as most older 2 strokes do) and is very rich (lots of smoke) and often dies.<br /><br />When warmed up to normal operating temp for a few minutes, then slowed to idle, engine will usually die and must be restart with high idle lever pulled up (very frustrating at the ramp).<br /><br />I bought the boat and engine last year from a friend who had already been pre-mixing the fuel due to concerns and fears about the VRO system. He could not remember whether the engine developed this problem after removing the VRO or if it happened before the removal.<br /><br />Does anyone know if the idle orifice jets need to be resized after disconnecting the VRO? The ones in this engine are stamped with 30, which I assume is .030 inch, judging by the apparent visual size. Does anyone know if this is the proper size orifice jet for an elevation of 500 to 1000 ft above sea level? Any other suggestions? I have looked for all of the obvious problems. Help! Sorry for such a long post.
