Can anyone tell me how to get more performance from my 1979 Evinrude 100HP outboard...It runs fine and is jetted properly...however I'm at 5-6000 ft elevation. Searching the database I get bits-n-pieces that the 79 100hp and 115hp basically are the same...only difference is carbs and exhaust...is this correct...what about intake/reeds/ports...Comments have said that this mod might not work and just cause excessive fuel consumption but the 115hp carbs have bigger diameter throats thus allowing more air/fuel (w/ proper jetting) right?...What exhaust modifications need to be performed...what year frames will these parts cross-over to the 100hp...Instead of carbs/exhaust how about shaving the heads for higher compression?...Can anybody give me specs on how much to remove and part #'s for thinner head gaskets...do I need colder plugs and their part #'s... What octane gas do I need for this modification...Most importantly if there is a flat out recommendation not to shave the heads please tell me why. Thanks, rennevat.
