strange throttle cable problem
stwbill
91 johnson 250,twin setup.starboard throttle cable will jam while running(cant return to neutral)and will tach up in neutral.control moves freely while the motor is off,and will shift easily.Why is this happening only when the motor is running?PLEASE HELP
rodbolt
Re: strange throttle cable problem
hello<br /> I am confused on your post. are you saying the throttle wont move or that it will return to idle but not shift out of gear ?
stwbill
moves freely while motor is off.will go into gear while running,but control will not return to neutral.can freely move the throttle at the motor as well.wont shift out of gear while running.will tach up in neutral.
wiserboy
Dose your motor have tilt/trim,,, If so try to start with trim down,,,
seahorse5
If it won't shift to neutral while the motor is running, then the shift interupter switch is not activating. It cuts out cylinders to momentarily run rough and "unload" the clutch dog lugs from the forward or reverse gear. The manual shows how to check and replace the switch.
rodbolt
hello<br />Gotta go with seahorse. test that switch :) :)
stwbill
thanks for the info,would that also cause it to rev up in neutral?(all this came about at the same time)
outrigger
My 99 130 did the same thing. It would not go back to neutral once the rpm's came up. What I found was the throttle was not closing the carbs enough to bring the RPM'S low enough to shift back to neutral.<br /> The engine would not go into neutral if the RPM's were over 1500....
stwbill
outrigger,was the cable bad or need adjustment?I appreciate the help guys,this one is not making any sense,I am thinking a bad throttle cable.luckily I have a spare twin control setup
outrigger
No all the cables were new. On the top of the engine I had to adjust the set screw. On mine there was a plastic piece that connected both carbs. When it was in neutral I backed out the screw made shure the butterfly's were closed and then put it back tight. I have not had a problem since. It did take a few times to figure out what to adjust and I tried everything from adjusting the cable to changing screw positions. It was getting agravating to say the least.<br /><br /> James<br /> Pictures of the boat are on the link at the bottom of the page. 2 years worth
Hooty
That's an ace boat, James. Super job!<br /><br />c/6<br />Hooty
