Hello<br /><br />I have a 1996 Evinrude 225 hp v6 looper carbed outboard. The powerhead was recently rebuilt and has about 15 hours on it. I am now pre-mixing my oil a 50:1 (used 25:1 during breakin).<br /><br />Here's the problem...I have had idle problems from the very beginning after the rebuild. It will prime and start fine and idle for a couple of minutes and the shut off...it will start right back up. The motor has a new VRO pump, stator, totally rebuit carbs, primer bulb and fuel lines. I just had the 10 hour check up with a different mech and he said the motor in great condition...even compression on all cylinders at 100...the timing was 1 deg retarded and he suggested that we leave it there...I check the plugs frequently and they look just right (light coat of oil and medium brown in color) there is no buildup on the plug surface indicating a lean or rich condition. Anyway, the motor just doesn't want to idle in or out of gear...it idles at 900 rpm and then stumbles to 700 rpm and then dies...it starts right back up...sometime it will go into gear and run PERFECT...most of the times it just dies.<br /><br />Also, after we run the motor for about an hour going out to the fishing spot and we sit for about an hour...we will have to reprime the build to get the motor to start...otherwise it will just crank and crank.<br /><br />Any ideas about what the problem is?<br /><br />Thanks
