Re: idle - starting problems
2k boat:<br /><br />I am aware of the internal check valves in the intake manifold...I doubt there is a problem with those valves because the reman ph company would have used new internal valves...however, I am going to replace the external recirc fittings and hoses.<br /><br />No problem about asking the other question...I plan on using AUGIDAWG's method of adjusting the timing if necessary.<br /><br />Anyway, I orderd the parts today and an ACTUAL shop manual from Bombardier for my specific motor...the Clymer manual leaves alot out.<br /><br />I'll let you guys know how it turns out.<br /><br />Thanks again!
