Re: What's wrong? - 1990 Johnson 120
Sunbird.... It's always possible that a new thermostat could be faulty. Switch the entire thermostat housing assy netween heads to see if the problem also switches.<br /><br />Are the springs within the thermostat housing the same? Is it possible that one of the diaphrams that the thermostat housing screws into is backwards? (don't recall if that's possible or not but it's worth looking into).<br /><br />The head that's running cold.... Is the thermostat seat/seal secure and exactly where it belongs (compare with the other head).<br /><br />You say that when you pull the plug wires off of the head that's running cold, there's no change in the rpms, but when you pull a plug wire off of the other head, it runs rough? If that was indeed the case, when you remove the plug wire from the warm head, the engine would be running on one cylinder which is impossible. Remove both wires from the cold head..... what happens?<br /><br />If the thermostats prove to be okay along with their related springs, seats, etc, it would seem likely that the problem on the cold bank is ignition related. When this problem takes place, remove the spark plugs (all), rig up a spark tester of some kind whereas you can set a 7/16" gap, then crank the engine to observe the spark.<br /><br />The spark should jump that gap with a strong blue lightning like flame (really a strong snap), not a flimsy shinny thread like spark. Let us know what you find.
