What's wrong? - 1990 Johnson 120
93bronco
Ensign
Re: What's wrong? - 1990 Johnson 120
sorry sunbird, i was under the assumption that if you didnt have them grounded it would hurt something. (especially the powerpack)<br />-<br />good luck with the 120.
sunbird1
2K don't worry about it. I appreciate the input.<br /><br />I am going to get a torque wrench this week so I can pull the flywheel off. I haven't checked the manual yet, but do I also need a special puller and something to hold the flywheel while I loosen the nut? I'll keep you posted on my progress.
93bronco
Ensign
best thing to use is an impact wrench, believe me thats easy.<br />the problem is getting flywheel off.<br />not really a problem unless you had an idiot like the one who sold me my motor and used loctite high strength red on the flywheel nut.<br />from there it seeped into the taper, or he put it there.<br />i used a harmonic balancer puller to pull off.<br />actually i destroyed the 1st one.<br />-<br />the center nut is 1-7/16 in. i got the socket (great neck) from autozone. for less than $10- it was just rite to fit for the ID of flywheel. you have to look at the sockets to get the thinnest wall.<br />i did get a holding tool, from K/D tools(actually a flywheel turner) but it did the job for less than $20.<br />-<br />when i put it back on, i used an old damaged head from the spare block i have with a piece of 2X4 to<br />hold it in place.<br />then i put resurfaced heads on.<br />-<br />book says to retorque nut to 140 to 150ft lbs.
sunbird1
Just wanted say THANK YOU and update everyone whou provided advice - it was the stator. Took the boat out yesterday and she ran great. But would you believe it, when I got back to dock, the trim motor crapped out and just when I was starting to like this boat again.
chuckybaby
B.O.A.T.<br /> <br />Bring<br />Out<br />Another<br />Thousand
93bronco
Ensign
glad to hear you got that problem figured out.<br />im still tinkering with mine.<br />-<br />im in the market for a tilt motor as well, been trying to find a used one but they want as much as a new one.<br />will probably go with the arco unit.
sunbird1
2K - I think I read a post somewhere that talked about just replacing the brushes. I may give that a try first before shelling our more cash. I think that is all my problem is because if I tap the motor with a hammer while pushing the tilt button, the motor works. Good luck with yours.
