1958 Johnson 18 questions
petrolhead
Hi everyone, I'm new to this list and have a couple of questions about a 1958 Johnson Seahorse 18 (FD-12) that I just bought. <br />Firstly it has a weak spark on one cylinder, I'm not yet familiar with these engines and would like some suggestions as to what the problem might be?<br />Secondly, the engine is in great shape and has probably seen little use, but it's acquired a bit of hangar rash and could do with some cosmetic work. Can anyone tell me the paint code for the metallic red please?
SCO
Re: 1958 Johnson 18 questions
Hello there Petrol,<br />I have one of those engines. The parts are available new and don't cost too much, but as a first check I would make sure the points look good and are gapped the same on both sides by inspection(can do this without removing the flywheel), the spark plug wire is good , and all looks good. You could swap the good coil and see if that solves the problem as maybe all you need is a coil. You will have to remove the flywheel to do this, and that is a bit tricky. You might search for some posts on that as it has been covered well. Dont put a standard jaw puller on the flywheel as you might ruin the flywheel, there is a proper tool for that job. You can get the service manual for that engine. On my engine, the insulations had deteriorated to a degree that I just decided to replace all the spark components(coils, wires, condensers, points).The flywheel magnet must be good since one side works, but the gap on the bad side could be off. I cant think of anything else. Good luck.
Chinewalker
Hi PH,<br /> Your old 18 is a great motor. One of the best designs ever, IMHO.<br /> More than likely you'll find the coils cracked when you dig into the magneto (under the flywheel). Invest in an inexpensive harmonic balancer puller to properly remove the flywheel.<br /> You can replace everything under the flywheel for under $50.00 so if things look questionable, I'd go for it. You shouldn't have to do it again in your lifetime.<br /> As for pain, try Peter McDowell's stuff. He's linked off the AOMCI.org site's link page. You might also get lucky and find some touch-up maroon at the autoparts store that is pretty close, too.<br /> Make sure you run your motor on a richer than modern diet of 24:1 or 32:1 mixed fuel/oil. Run good quality TCW3 rated oil, in mid-grade gas.<br />- Scott
petrolhead
<You might also get lucky and find some touch-up maroon at the autoparts store that is pretty close, too.><br /><br />I can get any colour I like mixed for me by the paint suppliers I use at work, as little as 0.5 litre, so I may as well have the exact shade. It's just easier for them if I can give them a code#, otherwise I give them a part of the engine and they'll mix and match to that.<br />I'll have it mixed in 2 pack acrylic which should last well.<br /><br /><Make sure you run your motor on a richer than modern diet of 24:1 or 32:1 mixed fuel/oil.><br /><br />Are you saying to use MORE oil? The guy at my local outboard centre suggested I might get away with LESS, as modern 2 stroke oil is supposedly better than 1950s oil was.<br />I don't know about this and was just going to use good oil in the recommended proportion of 24:1.<br /><br />Thanx for yours and SCO's advice on the spark problem, it confirms my own thoughts on the subject. I have a manual on order and will service the motor myself when I have it, in the meantime I may have a service done by the guys at the marina to get it sorted and running. The motor cost me so little I don't mind spending a bit to get it right, and they will have all the special tools that I don't.<br /><br />When it's ready the motor will be hanging on the back of a stretched (11') Glen-L Squirt that I'm just finishing. Two other guys who have built the same boat, and who are using the same motor on theirs, tell me it goes like a rocket on 18 horses, I can't wait!
gsnyder
I restored my '56 Johnson AD-10. Original outboard paint is available at the following website:http://www.axxent.ca/~nymarine/ You can also get to this link with a Google search for out board motor paint.<br />Additionally, I found original decals at www.americanoutboards.com. The cost for the holiday bronze, and the white paint was about $65, and the decals about $40. The motor looks fabulous.
SCO
Sounds great Petrol. The modern diet is 50:1. This motor I hear from Scott has sleeve bearings and needs the richer mix of 24:1. <br /><br />Scott, will we do ok with 32:1 on this motor? Id rather run the 32.
petrolhead
<Original outboard paint is available at the following website:http://www.axxent.ca/~nymarine/ ><br /><br />A useful looking website, unfortunately the shipping costs from the US to the UK would probably be prohibitive, assuming they can actually ship paints which I'm not sure about.<br />At least I know the name now, I'll ask my paint supplier if Holiday Bronze means anything to them, they may be able to cross reference it. <br />I already found the decals at American Outboards and will probably order a set, although they are slightly different as the number 18 on my engine is in italics, their decal has it upright. I suppose I can use the rest and handpaint the number in the correct style.<br />As you have used their decals perhaps you can tell me if they can be lacquered over safely, and if so, what type of lacquer did you use?
BillP
Hey Petrolhead...couple of comments here:<br />I'm with Chinewalker about the coils. If they are original it is time to change them. They are one of the first items I change on old outboards. <br /><br />On the decals...also try ebay. I bought some repro 1940 Sea King decals for about 1/3 of the American Decal place. <br /><br />About the paint. Over here in the USA we can take a sample part with the color to the local hardware store and they match with a computer. I did this on a full scale airplane to match the original for a repair. It was perfect. There is no guessing with this method.
Chinewalker
Hi SCO,<br /> Yes, you can likely run 32:1 on it. Some guys even run them leaner at 40:1 or 50:1. It's all a matter of preference and how much you value the motor. Personally, I would never run a pre 1960 motor of any brand on a 50:1 mix - parts are just getting too scarce. The 18s have enough roller bearings to warrant running a little leaner than the 24:1 I run in the 3/5.5/7.5 models. The little ones have bronze bearings throughout...<br /> Running it at 50:1 COULD be bad for the motor. Running it at 32:1 WON'T hurt the motor... If you're restoring it, why not err on the side of caution when you run it?<br />- Scott
petrolhead
Thanx for the advice Chinewalker, I think I'll play it safe and run mine on the 24:1 mix that they recommended at the time, with the best quality modern 2 stroke oil that should provide adequate protection.<br />My other outboard is a 1961 British Seagull Forty Plus, that takes 10:1 gas:eek:il, so 24:1 seems pretty good in comparison.<br />Also, I come from a vintage model aeroplane background, and we run our ignition engines on a 3:1 mix of Gas:Castor Oil, some call it cough mixture!
