Hi all.<br /><br />I just pulled the lower unit for service, as there was water in the oil. <br /><br />Whilst the LU is off the engine; I figured it would be a good time to rebuild the water pump. ..And maybe prevent another LU removal in the next few years.<br /><br />Questions:<br /><br />1. What would you regard the life expectancy for a water pump?<br />2. There was a very slight amount of burned plastic material just outside of the water pump housing. The water pump housing appears intact and in good shape. Would it be a mistake to re-use the housing, assume I put a "rebuilt kit" in?<br />3. My service manual recommends a few "OMC$$$$" sealants and lubricants: Are there suitable alternates for "Adhesive "M", "OMC Gasket Sealing Compount" and "OMC Moly Lube?" I admittedly do not like going to the "OMC dealer." I regard them as extortionists. Any good substitutes for this?<br />4. Finally, are there any good recommendation or tricks for re-sealing the lower unit, outside of what's listed in the service manual? <br /><br />Many Thanks!<br />Ken Ameika<br />Red Bank, NJ
