stoked not
Thread starter- Joined
- Jul 20, 2001
- 143
Well decided to go out striper fishing on the Chesapeake bay last night, really wanted to see if I still had water intrusion on my lower unit. I recently replaced the prop seal's and O'ring, Shift shaft seal, drive shaft seal's and complete water pump replacement. On the run out the motor started to hesitate and bog, mainly when I hit wakes could this be some sort of bad connection or wire. To make things even worse we called a short night and when I got home, YES I'm still getting water in the L.U. I'm going to get a pressure and vacume test done. Any idea were this water is getting in. I 'll keep you guy's posted on my findings<br /><br />Motor<br />1991 Johnson 225<br />Stoked Not
