Sean Murphy
- Joined
- Nov 2, 2003
- 2
1968 Evenrude V4, 65 HP Outboard.<br /><br />Here is the deal. I bought my first boat this season. I had it out a few times this summer. It ran ok but seemed to reach top end RPMs after a long (20 second) delay from the time I moved the throttle all the way forward. I was just getting used to this boat and "feeling it out" a bit. It's an old boat and I wanted to get to know it first. I decided that it was running good enough to open it up for a longer duration rather than my 1 - 2 minute full throttle spurts. Then it happened. After about 10 minutes it just quit all at once *poof* with no hint of ever starting again. No spark whatsoever. After I got it home and looked at it I noticed that a wiring harness that was around the rear of the engine and right above a very warm rectangular electronic component was in very bad condition. The insulation was crumbly and some wires were now bare and shorting. Could the rectangular object be the power pack? My first diagnostic guess would be the coil fried but I am learning that it may be the power pack or both. Obviously I have to replace that harness or build one myself if possible. <br /><br />What should I start with after the wiring is replaced if I still have no spark? <br /><br />My local outboard mechanic is out of his gourd with his estimate so it looks like Im going to be doing it myself as I am having a hard time finding a shop to even take the job. I am convinced this could be a good motor, after all it ran nicely when I got it.<br /><br />I may also need to replace some seals in the gear case? The oil seems to be turning a tiny bit milky as if it may have water in it.<br /><br />Im sure you can see that I am a bit new to outboard motors and boats. I am glad there is a site like this to offer a helping hand to guys like me. <br /><br />Thanks in advance for any and all help.<br /><br />-Sean Murphy<br />313-824-6502
