Re: Timing pointer alignment?
I have used such a tool many times.<br />When I read in the Johnson manual about the piston stop method, I really liked it.<br /><br />The dial indicator is ok, but when the piston appraches top dead center, the ratio of degrees rotated to thousands of inches of piston movement, becomes null.<br />In other words, because of clearance in the top end bearings, bottom end bearings, main crankshaft bearings, the crank can rotate without any sign of piston movement.<br /><br />With the piston stop method, you are taking up all of the slop in all of the bearings, and the farthur from TDC you stop the piston, the more accurate the measurement becomes. Half way between TDC and BDC would actually be the best, but there are no timing hash marks that far away.
