Re: 1995 Johnson 200 OceanRunner Trouble Starting!
Pump the fuel bulb before and after it pops.<br />Replace the plugs with QL78YC, if that doesn't work, try the QL82YC plugs. Don't run that hot plug at extended high rpm.<br /><br />When you get done boating for the day, run it at high rpm right before putting it on the trailor.<br /><br />The day before you go boating, run it on the muffs for 5 minutes. It will run leaner, and blow out the extra oil in the bottom of the crank case.<br /><br />If this doesn't help, advance your idle ignition timing a couple of degrees by turning the screw counter-clockwise 2 turns.<br /><br />If this doesn't work, take it into the shop. You either have carb or ignition problems. Might be that your "quik-start" is not advancing your ignition when the engine is cold.
