More Info Needed-Can You Identify This Motor
calwing
I did some scraping and cleaning this morning and found a few numbers on this old Evinrude but I think they are just part numbers???.<br />-39A is stamped on the fuel tank<br />-10B is stamped on the bottom of gear box<br />-1B is stamped on block<br />-spark plug is an X-46 Edison<br />-g<br /> 3<br /> -<br /> 8<br />52 - is stamped gear box<br /><br />It is mostly made of brass - prop,leg and all screws and brackets.<br />Just a bit more info if anyone can tell me were to get a manual and or parts book. Am trying to find out year model and worth<br /><br />Thanks<br />Cal O :confused: in Canada
rolmops
Re: More Info Needed-Can You Identify This Motor
I cannot help you a great lot, but brass was used before worldwar 2. A rough guess would put it somewhere before 1940.<br />If you could post a picture,you would probably have an exact answer in five minutes flat.
Hooty
Here's a good site for info on old engines.<br /><br /> Old Ingins <br /><br />c/6<br />Hooty
calwing
Pictures: I now have some pics of the old Evinrude and could send to someone who could tell me what it is.<br />Thanks - <br />Cal O - in Canada
rickdb1boat
You can send them to me and I will be happy to post them on here for you. In the message, put "More info Needed", so I remember where to post them :) <br /><br />rickdb1@earthlink.net
rickdb1boat
Pics of "Cal O's" old Evinrude. Can you identify it??<br /><br />
<br /><br />
<br /><br />
<br /><br />
<br /><br />
<br /><br />
ezeke
I think that is an 1918 Evinrude.
rickdb1boat
Just wondering if any of these numbers or letters given match any of these:<br /><br />A(#3000-7200) 3,5 1915-22 <br />A(50000UP) 2 1915-28 <br />A(TWIN) 3 1923 <br />AA 4 1916-17 <br />B(#5000-7200) 3,5 1915-22 B(55000UP) 2 1915-28 301 7 1929 <br />B(TWIN) 3 1923 <br />C 2 1916 C(TWIN) <br />D 2 1916 <br />D(TWIN) 3 1924-25 <br />E 3,5 1915 <br />EE 4 1916 <br />F(#F0110-F4000) 6 1928 <br />F(#1F001-4F300) 7 1929 <br />G 4 1926 <br />H(#H1001-H2500) 12 1928 <br />H(#1H001-13H250) 14 1929 <br />H(SINGLE) 3,5 1913-14 <br />H(#30000UP) 4 1926 <br />J 4 1927-29 <br />K 4 1927-29 <br />L 4 1923-26 <br />LA-LAT 4 1923-26 <br />N 2,5 1923-28 <br />NF 2,5 1929 <br />NS 2,5 1923-27
rickdb1boat
Might have looked like this at one time. This is a 1918 Rowboat Motor.<br /><br />
<br /><br />
rickdb1boat
Info from Walter:<br /><br />
<br /><br />
<br /><br />
rolmops
Hello rick.<br />Is the old one a 1912 knuckle buster?
rickdb1boat
rolmops <br /><br />That's the big question. The others that I posted are from 1918. Cal O was trying to comfirm what year it is. ?????
rolmops
If we go with the "B" we can date it after 1915. It does not say "The Original Evinrude" so that puts it before 1922, the year after Ole introduced the Elto.<br />That would put 1918 right there in the middle.<br />It is possible that there are "A" and "B"parts on one and the same engine because simular parts were cannibalised from another engine to keep this one running.This was very common in the lean 1930's.<br />On the earlier ones there was a tin plate with square lettering.On this one we see that the name is in cursive and part of the cast.<br />Where are steelspike and chinewalker when you need them? Scott has probably seen it in the old outboard museum. It is in his neck of the woods.<br />Am I making sense so far,or am I just far out there?
ezeke
The only thing that bothers me is that I don't see the engraved name plate on any of the comparable motors. I know that it is on the 1920 because I have the Ad. 1920 Evinrude <br />[I wish Rick would tell me how to post a photo on this site. :) ]
rickdb1boat
ezeke <br /><br />MSN is tough to get pictures to link from. I use earthlink as my webpage and it's easy. So is geocities . Might want to try and get an account their and then you can link your pics from their site. I can pull up the small preview version of your pictures on MSN, but when I enlarge them, it won't let me link it. For example:<br /><br />
<br /><br />or <br /><br />
<br /><br />But that's as big as I can get them from MSN. I just right click on the little preview picture on your site and pick properties and copy the address(URL) Then when I reply on this site, I paste it in the image box. Some sites you can link easy, some you can't. This site you can! Try it on any picture above! Just preview your post, but don't actually post it. Don't want to see the same picture twice, do we?? :)
Chinewalker
Okay, what we have here is a pre WWI Evinrude Rowboat motor, I am guessing c.1912 or 1913. It does not have the reverse feature that the 1918 models show (twist the tiller handle and the lower unit walks around backwards). It also has the smaller filler cap in the gas tank, typical of 1909-1912 models. It DOES have a skeg, which 1909 and early 1910 models did not have. It DOES have the embossed Exhaust casting which the very earliest motors did not have. It is battery ignition, making use of a buzz coil and HotShot battery. It is missing the exhaust can. The original ID plate would have been soldered to the tin gas tank in the rear/top. The very earliest motors didn't have a model number stamped in the plate, just a serial number (I have #790).<br /> Hope that helps...<br />- Scott
rolmops
Hello Scott.<br />The oldest known Evinrude is the 780.Is it reasonable to think that you are the proud owner of the second oldest known Evinrude?
Chinewalker
Hi Rolmops,<br /> Actually, that was a typo on my part. Ours IS #780. It's on loan to the Thousand Islands Bridge Authority/Antique Boat Museum in their joint display at Boldt Castle.<br />- Scott
