Re: 7.5 Fleetwin
Model# 7516<br />1954 Evinrude 2 cylinder<br />HP: 7.5<br />WOT RPMS: 4000<br />Displacement 12.4CID<br />Weight: 49 lbs<br />Plugs: Champion J6C<br />Fuel Oil mix: 24:1 TCW-III oil (and stick with it, this is a babbitt bearing only engine)<br /><br />To remove the lower unit to accesss the water pump on this engine, the shift mechanism must be disconnected. The only attachment point is at the shift lever pivot, which is underneath the powerhead. So you must remove the powerhead to service the water pump's impeller. It's not a difficult task, but you will need a new powerhead base gasket. A manual would be very valuable to you. You can order an aftermarket one here from Iboats, or you can get an OEM (OMC) reprint from kencook.com, and somtimes EBay.<br />Parts can be had from a Johnson/Evinrude dealer. Napa autoparts and various online places carry some aftermarket parts for this engine.<br /><br />Good luck!
