I have a 1998 30hp Johnson motor.<br />I took the lower unit off the other day and took apart the water pump to make sure everything looked okay. When I put everything back together and started the motor the propeller started to turn, there was also a rubbing sound. How can I correct this problem? Do I need a new impeller? Also no water was comming out of the pee hole or whatever it is called, is there any chance that I hurt my motor?<br /><br />Thanks, Nick
