motordummy
- Joined
- Nov 2, 2003
- 19
Will leave the unnecessary details out as to how this came to be-youth and of course beer were involved. But once upon a time there were two 1959 10hp johnsons. both ran well. one day about 12 years ago, one of them sunk in the water while running at idle. it was never worked on or even attempted to be started since. it was kinda gonna be used as a parts motor for the other one. the one that survived, later had a shift problem-clutch dog and forward gear. parts motor dog and went on to running motor and it continues to run happily ever after. now, i am looking for a potential winter project to get me out of the house and have had some dark dreams of potentially reviving the old one. two issues.<br /><br />first, regarding the engine (block, head, cylinders, rings, anything that would be ruined by going down while runnin and sitting that long) what and where might i even start to see if there has been internal damage beyond repair, and what would most likely be fried? does this, in and of itself, put this project out of sight or might this baby be able to run? thoughts? parts sources?<br /><br />if the engine were to run after whatever overhaul would be necessary, i then have the lower unit issue with the clutch dog and forward gear. are these parts even still available for this motor or would i have to look for salvage? i know these lower units were far from invincible so i was hoping that there might be quite a bit of old stock somewhere in the world as alot of them would need to be fixed. if not, anyone ever had a machinist make them? does anyone know part #s or a potential source? the gear teeth look ok all around so i could potentially just swap forward and reverse gears and turn dog around and only have the issue in reverse, but if i,m gonna do this i would like it right. obviously, lower unit will not be an issue unless i can get fired up and running dependably. have a factory manual on way so that would not be a major issue though it would be my first outboard teardown project. i am however quite handy with car engines so this doesnt worry me. i am not lookin to spend an arm & leg. thanks for any advice on this.
