Hello,<br />I have a 1985 140hp Evinrude. I bought the boat last summer. I just got the boat out of the shop with an intermitant ingnition problem that turned out to be a bad coil. I took the boat out last weeekend and experienced some new problems. When I got out of the no wake zone I opened her up and she reached 5,000 rpm very nice. I slowed down to idle and tried again and it only reached about 4,000 rpm. Next time it slowed out and stalled. After shutting down and drifting for about 10 minutes I opened it up again to 5,000 and it started to die after about 10 seconds then did stall. I tried to restart and the motor would not turn over. This happened several more time back in.I took it back to the shop Monday and got it back today. This is what he said...The VRO no oil alarm went off when they ran it in the tank so they swithed to thier fuel tank. The bogging was more than likley caused by the cheap primer bulb. A long story short. I might have had an oil failure. The motor not turning over could have been the engine stating to sieze. Also a slight knock coming from either the no.1 piston or the top bearing. The top bearing does have some lateral motion. How much if any is acceptable. Sorry for the long post. Any help would be great.
