steviecops
- Joined
- Oct 3, 2003
- 585
I have a 1980 Johnson 55, 2 cylider, electric start.<br /><br />I changed my spark plugs today, and went to run the engine but it wouldn't start. I put the old plugs back in, which were fine last time out about a month ago, but it still wouldn't start.<br /><br />When I took the new plugs out, I noticed they were dry, as if no fuel was getting through to them, so I started to check the fuel system.<br /><br />I noticed that fuel was being forced out of the fuel pipe/pump connection when I pumped the bulb. Not vast amounts, just slight seepage.<br /><br />When I disconnected the fuel line from the engine to try a different tank with new fuel, fuel spurted out of the connection under pressure. Also, when I undid the screw to check the filter on the fuel pump, petrol spurted out from the fuel pump under considerable pressure. It seems to me that the fuel isn't getting any further than the pump, and that there is back pressure building up there when the bulb is pumped.<br /><br />Does this make sense? If so, will a fuel pump kit remedy the problem?<br /><br />Another thing I saw which worried me, was a brown, waxy substance which looked as if it had dripped from the top coil onto the head, as if it had melted and dripped down. Is this anything serious? Any ideas what this is and what has caused it?<br /><br />Sorry for the long post, but I'm trying to put as much information as possible on here in the hope that someone may be able to help me.<br /><br />I would be very grateful for any advice.<br />Thanks in advance.<br />Steve
