steviecops
Thread starter- Joined
- Oct 3, 2003
- 585
Re: Please help. Engine won't start, suspected fuel problem.
I removed the solenoid spring from the choke flapper and operated the choke by hand. The choke plates return to the open position when I release them, as if by gravity. I've also operated the choke solenoid plunger by hand, and it seems to binding on the way out at one particular point. ie, when the plunger is pushed all the way in, it binds for the first 5mm on the way out, and then frees up and pops all the way out.<br /><br />I don't know if this info is of any use.
