So far I have replaced thermostat-engine overheats alarm sounds. Replaced water pump w/housing./Engine overheats. Engine overheats after about 4 minutes of 3/4 throttle operation. I can remove thermo and proceed without any problems. I am aware of some TSB's concerning this issue. Flow indicator nipple has been relocated to top of ex. manifold and restrictor removed by previous owner. Waterpump kit contained red straight spring and conical yellow spring + new thermo cover; but, no instructions. I installed red spring and stock cover. I am aware of new temp sensor p/n. My tan wire overheat sensor must be working correctly because when motor overheats it is very hot. I have to pour water on thermo housing to cool it, so I can remove thermostat without burning my fingers. This is and has always been a fresh water motor. Waterflow out of motor with thermo cover removed is substantial. I also tested new thermostat in a pan of water with themometer, it opens at correct temp. Compression is even 110 psi, motor starts and runs fine with termostat removed. Cold engine is killing my fuel economy and no doubt cokeing up motor. Any suggestions? Thanks!!!
