Re: 115 head swap will it interchange??
I understand your question isnt about changing motor or boat,but about improving your speed with what you got. 5600 rpm with your 15" and 15% slip should normally give you 34 MPH. I calculated your slip to 36 %. If I did it correct, maybe it would be a good idea to borrow a 13" prop to try.<br />If you are able to reduce your slip to - let say 20%, it should give you 30 MHP at 6000. But depending on less slip. I think 36 % slip is much, but not sure if I calculate it right.
