seconddraw
Thread starter- Joined
- Jul 28, 2003
- 11
First off, thanks for all of the help over the past couple of years!<br /><br />I have a 1992 Johnson 40 with two carbs. On the top of each carb, near the back, there is a 90 degree brass fitting with a tube that connects each fitting/carb. Well, the bottom fitting is bent at the seam and broken. I have been having a problem when running the boat. She idles fne, but when powered up with load, she bogs down. A complete loss of power. I have checked fuel pump and spark and all checks out fine.<br /><br />My 2 questions are this; Would this fitting cause the engine to bog down and if so where can I get a part like this?<br /><br />Alright, 1 more question. What is this part and what does it do? Thanks for all of your help!
