Tonygotskilz
- Joined
- Apr 19, 2003
- 38
Hello, i previously had trouble starting my 1972 50hp Johnson Hydro-electric shift and i looked in the faq but i'm still not sure what the problem is.... <br /><br />Ok My engine ran fine 2 weeks ago, but one day i started it up and got the over heat horn (Started before motor even started, horn would sound when i turned key, then motor started just fine... but horn kept going) so i shut it down and 2 days later i tried to fire it up again and NOTHING... Batteries fine, i thought it was the starter relay, replaced it still wont' start... I measured voltage at the relay and there was no change (when checking top wire and bottom wire on relay while turning the key... the voltage was around 12.4 constant before turning key after and during) when you try to crank motor... No click from relay and no motion from the starter...<br /><br />Anyone have any clue whats going on? Weird thing is when you turn they key to on, or start you can hit the toggle switch for the choke, and the choke moves, so i know the motors getting power, but it doesn't want to turn over, its in neutal when i try all of this but i'm thinking that maybe somehow it doesn't know its in neutal and hte neutral start switch is giving me the trouble... Can i disable it and try to start? I opened the control box and it looked like all the wiring was in tact but i have no clue what i'm looking for... Any help would be greatly appreciated, i'm just trying to get this working so i can sell it and the boat its attached to...
