Aluminum vs. Stainless
elwilliams13
I heard somewhere that a stainless prop's heavier weight puts more strain on the gearcase than the lighter aluminum. Any truth to this?
VistaMan
Re: Aluminum vs. Stainless
With higher power motors it would put more strain when shifting into gear, especially if it has a high pitch.
elwilliams13
I have a 14 1/4 x 18 on a 1991 225 evinrude. It seems to shift pretty smooth not sure if shift switch is working.
VistaMan
On racing setups, with pitches of 25" and more it is normal for the motors to be started in gear to make it easier on the lower end. I know of people that have striped gears over a summer like this but shifting into gear after starting, the inertia of the prop weight and high pitch realy does a number on the gears!
walleyehed
Under water, (hydrodynamics) The Blade area has way more significance than the Weight of the prop due to the fact that under water, gravity has 2/3rds less effect. 18lb. prop out of water weighs 6lbs. under water.<br />They both have a rubber hub to absorb shift impact, and the weight has very little to do with it.
VistaMan
I agree that the weight under water is less but then a SS prop will still have more inertia to overcome, the specific graity of aluminum is about 2.5 and SS is about 8, 3.2 times heavier! But , yes, the blade area is the predominant factor so a high pitch prop will give more 'clunk' to the gear case.
moderator1
Moving to General Outboard discussion. This may benefit many.
