1978 70HP Johnson, I haven't checked compression and am curious if low compression in a cylinder can cause flooding. I have completely rebuilt the carbs and I'm still having the same problem. The engine starts up great on land but after trailering it and putting it in the water it wont start. Today when I launched it in the water I tried to start it and It wouldnt, so I took out all the spark plugs and cleaned the oil off them and it fired right up. I let it run for a couple minutes to warm it up and then I shut it off. After It sat off for about 5 minutes I tried to restart it and It wouldnt start again. I noticed some fuel pouring out of the center carb.<br />I'm sure I set the floats correctly and the needle valves are brand new. The spark plugs are also getting a good spark. Does anyone have any ideas about what I should try next, and Also if compression may play a part in this?
