Re: tilt/trim motor leak
Sometimes a minute piece of debris holds a check valve open. Loosen up the trim release valve and cycle the trim motor both up and down for a few seconds each way. Lift the motor up manually and push it back down. Now tighten the valve and try the unit again. If it's debris, it should work OK now, if not, then it will have to be serviced.<br /><br />There are 2 types of trim units. The original style is mounted with 3 bolts on either side of the stern brackets, and parts are individually available. The "Fastrak" style is only held inside the stern brackets with a 1" diameter pin with snap-rings on each end. That unit has to be repaired by replacing the valve and pump assembly as a single piece, then cleaning out the whole system.
