refractory148
Thread starter- Joined
- Dec 20, 2003
- 50
I have 1998 25HP Johnson Model# J25RECB. I just purchased this motor on a small alum. boat. I brought it home and hooked it up to the water hose with one of those motor rinsing adaptors. I ran it for about two minutes. Everthing was fine it ran great and water was coming out of the pee hole. When I shut the motor off oil started to come out of a small hole at the top of the lower unit closest to the boat. The hole is maybe 1/8" and is located between the two "fins" on the lower unit on the port side. Is this a major problem or does the lower unit just need new seals? I drained the oil and it looked fine. Did not appear to be any water or any metal shavings in it. What made this happen???
