Re: Dhadley, Intake manifold mod.
I've got a stock intake manifold I've been looking at here, and am studying what you are describing to cut out. From front to back you have to cut all but 1/4" (remaining) on the crank side of the manifold....am I reading you right?? The divider between the 2 ports, looking from a side view, could the center web be removed in a "C" shape, like you took a bite out of the center....this would allow flow from both venturies, right???<br />Next, and final question...would it allow more power in the 6k range...as in more pitch capabilities, or would this simply increase the power curve at higher R's??<br />I think short of adding 2 more cylinders, I'm pushing it as it is now, and may just leave it as is.....it does run well, but always looking for a little more I guess.<br />Thanks!
