MoeBudz 420
- Joined
- Dec 22, 2003
- 2
hey, i picked up a '76 Ev. 15 hp from a friend, very clean, but sat for a few years unused on motor stand. Had a chance to test it awhile ago on a small john boat. Motor started, idled fine, put it in gear, took off. Lots of pep, snapped right up onto plane.After about 1-2 mins wot, rpm's dropped more and more, kinda like throttling down, but tiller still held at wot. Eventually will quit, require restart, same over again. I think the bowl in the carb is being filled by primer ball, then it empties at wot? Engine remains cool enough to leave hand on sparkplugs w/o burning it, good flow out of pressure relief hole (no peehole)<br /> Did not think to squeeze primer ball to check fuel pump pressure. It has to be either that or maube a blockage/plugged filter? Cannot test again till spring. Hoping it's something small!<br /><br />Any help appreciated!
