What is proper fuel:oil ratio
refractory148
I need to know the proper fuel:eek:il ratio for my 1998 Johnson 25HP Model# J25RECB. My 87 Johnson 20HP is marked 100:1, is my 98 25HP the same? Somebody told me it was 50:1 for this motor. I dont want to run it too rich or lean. The 25 doesnt have the little sticker by the fuel hook-up like my 20 does.
bubbakat
Re: What is proper fuel:eek:il ratio
50:1 should be the proper mix.<br />even on the other one I think they sent out a change on it changing it to 50;1 also
cobra 3.0
I have a 1997 15 hp Evinrude and I run 50 to 1. When it was brand new they recommended 25 to 1 for the break-in period. 100 to 1 is darn risky and I wouldn't do it. You are sure not to harm anything at 50 to 1.
nightstalker
50:1 is the proper mix. There were a few two cycle oils that were advertized to do the job at 100:1 but, they did more damage than good. They are not on the market any longer.<br />Stalker
walleyehed
OMC tried the 100:1 with there OWN oil and elected after less than 1 year, to go back to 50:1, as it came out via a service bulletin.<br />They did not take into account an ounce or so less by mistake caused serious problems at 100:1.<br />OMC claimed (admitted) there was not enough residual oil for protection against rust either.<br />Using standard oils, 50:1 is the ONLY way to go in both engines.
refractory148
Welli think that pretty much takes care of it. Thanks guys.Im sure ill have one or two more dumb questions before its over with.
walleyehed
No dumb questions here, they all deserve an answer! :)
