Maxxon Inflatables - anyone have experience with these?
18rabbit
Re: Maxxon Inflatables - anyone have experience with these?
Your typical inflatable does not plane. The tender that I bought from the guy that sold his sailboat is a Caribe. It has a snap in fiberglass keel; basically a two-part fiberglass stick that snaps in the bottom between a pocket under the tube at the bow, and the fiberglass transom. The fabric on the bottom is stretch very tight. It’s a 10-ft inflatable that will easily plane with 2 divers and all their equipment when pushed by a 15hp Yamaha. 15hp is the max motor size for it. I wouldn’t get too creative about over-powering an inflatable since there isn’t any real structural support except 3-lbs of air pressure.<br /><br />The boat size you mention is going to get real crowded with two divers, their toys, a helmsman, anchor, and the safety equipment we (in the US) are required to carry on all boats. It’s kind of silly but even tho you’re in a 7mm wetsuit with no possible way of submerging without a weight belt on, we are still required to have a PFD for ever diver on the boat. I wouldn’t want a boat the size you are talking about for anything more than two divers. Leave the helmsman at home.<br /><br />If you haven’t been diving from an inflatable before, you will quickly recount all those training exercises for doffing and donning your equipment in the water. We found it easiest to assemble the rig on terra firma and throw it into the boat. The weight belts moving around on the boat floor will be one of your biggest concerns. If you’re sitting on the tubes on your way out, don’t wear the weight belts. It’s a safety issue should someone bounce overboard. Once you are anchored at the dive site, inflate the bc’s and throw them overboard. Lay the weight belts on the tubes. Grab your fins and jump in. I have a couple lines attached to the boat so when a diver surfaces the first thing he does is clip a brass hook to a loop in his weight belt and drop the belt. It will hang about a meter under the boat. Another line to clip to the bc, then remove it. If you aren’t in currents you don’t need to clip the bc, if you are in current they have a tendency to float away. Oh, if you are in currents, get yourself at least 50 meters of polypropylene line (floats) and a small buoy to attach to the transom…it’s not “if”, it’s just a matter of “when”. It’s also more stuff to put into a small boat.<br /><br />Three people cannot carry my assembled, inflated Caribe across rocks if the fiberglass floor is in place, and it must be before fully inflating. It will take 4 people. If the Zodiac doesn’t have a rigid floor you should be ok with two people carrying it but you’ll still be dealing with bulk while navigating the rocks…and after the dive?!? And you are going to want to be careful to keep that vinyl boat off the rocks. It is NOT abrasion resistant. Fold a big towel into a shoulder pad and you can carry the 15hp motor without too much problem if you’re only going a short distance over rocks, unless you are one of those failed NZer bungee jumpers. :) <br /><br />I think the first couple times you launch your boat over the rocks you’ll be ok. By the third time your dive buddies will be finding excuses for not going. You’ll be looking for other location to launch your boat, perhaps from a sandy beach or such. From the sand you can use big, bulbous wheels attached to the transom and roll the whole boat+motor into the sea. Also, the size of boat you are talking about is going to be marginal for two divers, equipment and a helmsman in anything except calm water. You might be better off holding off until you can afford something (boat) a little more appropriate, or start a dive club and get some other dicers to invest in a boat, something like that.<br /><br />Edit: another thought… I have wondered why no one built fiberglass boats with tubes that look like inflatable boats. They would be excellent dive platforms. I just saw such a critter at the Seattle boat show. A small, fiberglass boat with fiberglass tubes that have hatches on the tubes for storing stuff inside them. If you have time, you could build yourself a boat like that for less money than a Zodiac costs. You would have a bigger and better boat, but you would need a trailer to haul it around on, and you would need to launch from a ramp…I guess a luxury you don’t have.<br /><br />Ever heard of a dive board? It’s like a surfboard on steroids, with a pointy end, no fin(s). They are a hollow fiberglass shell you can easily carry to the shore, strap your dive toys to the top, and kick out with your finned feet. No paddle. You don’t go fast but you can go far. There is a compartment for a small anchor and line. They are very popular with free divers, especially during spearfishing contests. Some scuba divers use them but scuba divers are basically lazy. :) You can buy dive boards but most people just make them themselves. Sea Kayak makes some indestructible plastic boats specifically for your type of diving. You should take a look at them. They are popular in California and have good resell value, well made. Some models have carriage bins for two tanks, even some models of kayaks for two divers.
Snowdrggn
As previously stated, I have a 13 year old PVC low end Zodiac. Is it equal to a Hypalon boat in durability? NO! But that said, I have been more than happy with it and am buying another PVC boat. I don't leave it moored, laying in the sun when not in use, nor use it in salt water regularily. It is carried, not drug or ran onto shore, kept clean, and treated carefully. The only reason I am selling the boat is that I want more interior space, and am replacing it with a larger one. PVC boats can serve long and well for their owners if treated for what they are and cared for accordingly. Consider what a day cruiser would look like if it was used regularily as a work boat? For a dive/work boat, if it is left in the sun, or exposed to fuel/chemicals, I would only consider Hypalon. The boat I have sees an average of 300+ hours of running time a season in all weather conditions, tows people around on kneeboards, explores small and large lakes, and gets used in rivers on occasion. As in any boat purchase, usage should be a prime consideration, and your decision should be governed with that in mind. A well built PVC inflatable from a reputable manufacturer can provide many years of enjoyment for the money spent. Unfortunately there have been many PVC boats sold that were/are of poor quality and construction. Whatever you buy, if it is not maintained and is abused, you will not get the life span, reliability, or resale value from your purchase.<br /><br /> Best wishes on your purchase.<br /><br /> Cheers,<br /> Snow.
Richard B
Snow and Rabbit, and all the others that have contributed - thanks for your help. I think I'll settle on a Zodiac, and hope that the 15 horses is enough to move it around.<br /><br />I'll let you guys know what it performs like!<br /><br />Thanks and regards,<br />Richard
boater4life
EDIT: Advertising is forbidden here, B4L.<br /><br />Your first clue was the deletion of your first ad.<br /><br />Please remove the link from your signature.<br /><br />Persist and you will be banned from the site.
