VRO? Yes or No
nightstalker
My 22' Sunbird Wac is ready to go. The 225 Johnson (1994) has had it's VRO system disconnected by the previous owner. Should I:<br />a. Leave it disconnected and premix at 50:1?<br />b. Reconnect the present VRO system, premix<br /> an auxilary tank and run to see if the system<br /> works?<br />c. Install a new VRO system?<br /><br />Stalker
OBJ
Re: VRO? Yes or No
Boy the worms are going to crawl outta this one. <br /><br />Nightstalker...if the engine is running OK without the VRO...let it be.<br /><br />If you decide to reconnect...Put a new pump on. Don't mess with something your not sure about and have a certifide wrench (one you trust) check it out for alarms and operation.<br /><br />A new pump will be in the $250 range.<br /><br />Just for grins...do a search for VRO pumps and look at how many post have been written on the subject. It just boils down to what you trust.<br /><br />Good Luck.
Salty Sal
Re: VRO? Yes or No
....And here's the first worm!<br /><br />Whaterver you feel comfortable BUT DEFINITELY<br />go wuth the newest VRO if you wish to re-connect.
