1986 Johnson 50hp AJ50TLCDE
lesmiller
Yesterday I took the family fishing, I was almost full throttle and suddenly there was a bang in the lower part of the outboard and the engine screamed as the prop stopped moving. The engine would not run properly afterwards, we got home on the auxilliary!<br />Does anyone have any sugestions as to the cause?<br />Many thanks
Joe Reeves
Re: 1986 Johnson 50hp AJ50TLCDE
Without investigating further, I would suspect a broken driveshaft.
moderator1
R.Johnson <br />Captain <br />Member # 33412 <br /><br /> posted January 06, 2004 07:02 PM <br />--------------------------------------------------------------------------------<br />With high revving of the engine, and sudden loss of motion, I would guess at a broken drive shaft, or shattered pinion gear. I say pinion gear because you said the engine also did'nt run right. I broken pinion, and the resultant friction could cause this. A spun prop hub would'nt make a bang, and stop cold. <br />--------------------------------------------------------------------------------
moderator1
Swebber,<br /><br />Please do not double post. Your original post has been deleted however the responses have been moved here.<br /><br />Thank You.
lesmiller
Thanks for that, i may have over stated the scenario, have just got back from taking the boat out again to test, it appears the engine is going fine but there is loss of pulling power, something is wrong with power to the prop, could the prop have sheared?
