Re: 15 hp evenrude conflicting assembly procedure
hello<br /> I always seal the outer portion of the sealwith Gel -seal. the reason your manual says different is to many people think if a 1/8th bead is good a 1/4 will be better. when torqued down the sealant oozes out everywhere. that is why they say stay 1/4" away from oil passages,seals and what not. this is another area where the book was written by an engineer that has no experience and edidted by a non technician and published. if ya really want to have fun try some of the jap or swedish manuals that had the same then translated by a translator to english.we call it swinglish and jinglish.so the easiest thing I can tell you is to wipe a thin bead of gel-seal around the seal,install it fully seated and assemble the block.<br /> good luck and keep posting. and always remember that common sense is the best tool in the box
